VisualARQ: Layer Visibility Issue in Shaded and Wireframe Mode
@fsalla Please help. I want to organize my VisualARQ styles so that objects are on “Material layers” and blocks are on “Part layers”, allowing me to change object properties globally via the Material layer settings and control visibility by toggling layers on and off. While working this way, I discovered a bug (see screen recording): in Shaded and Wireframe modes, the outline remains visible even when the Material layer is turned off this is not the case in Hidden ore other modes. Or am I missing something? File is attachted.
TEST FILE.3dm (77.2 KB)
I discovered something: the issue seems to be related to the ‘Model On’ option. When layers are turned on or off globally, it works correctly. However, I started using ‘Model On/Off’ to avoid affecting my layouts.
Hi @user2745 you are right, this is definetively an issue with the Model On/Off status. We will revise it.
Thank you. Is this somthing wich could be solved in the next Update ?
I hope so but I can’t promise it.
