I am trying to use VisualARQ within Tekla Structures via the Tekla grasshopper component. Via the Tekla live link it works perfectly but with the Rhino Inside Tekla component visual ARQ is not loaded. How can I solve this?
I am trying to extend my Tekla Structures with some architectural stuff, doors, windows etc… If Visual ARQ works within Tekla Structures then I am interested in buying Visual ARQ.
Hi, indeed it seems the VisualARQ plugin isn’t loaded when GH is opened from Rhino.Inside. This is whether or not you have the Tekla link installed.
Can’t see any error messages or relevant exceptions anywhere though, so hard to tell why it fails. Some reasons could be
The VisualARQ plugin expects an active Rhino document - we’re not loading any Rhino document at all.
The VisualARQ plugin licensing system somehow prevents it from being loaded through Rhino.Inside.
I think the VisualARQ team needs to look at this. I used the code below to test:
var rhinoCore = new RhinoCore(new string[] { "/NOSPLASH" }, Rhino.Runtime.InProcess.WindowStyle.NoWindow);
var grasshopperInstance = (Grasshopper.Plugin.GH_RhinoScriptInterface)Rhino.RhinoApp.GetPlugInObject("Grasshopper");
grasshopperInstance.DisableBanner();
grasshopperInstance.LoadEditor();
grasshopperInstance.EnableSolver();
var loadedLibraries = Grasshopper.Instances.ComponentServer.Libraries.ToList(); // VisualARQ missing from this list.
Yes, VisualARQ requires an active document, but I think Rhino itself does. Are you sure there is no active document?
No, our license system allows VisualARQ to work in Rhino.Inside.
Consider that VisualARQ is first a Rhino plug-in, not a Grasshopper add-on, so VisualARQ Grasshopper Compnents are not loaded until VisualARQ plug-in is loaded. To load VisualARQ, the user needs to open a document with VisualARQ data or execute any VisualARQ command.
Is it possible in Rhino.Inside.Tekla to run the command vaInit ?
Another option: in the script you posted, try to load VisualARQ plugin by calling the LoadPlugIn RhinoCommon function before checking the loaded Grasshopper libraries:
OK, I think the problem is that Rhino (or Rhino.Inside) is running in a different schema or profile, where VisualARQ is not registered. Do you know if that is true? I know that VisualARQ works in Rhino.Inside.Revit, so I guess this is something specific to Rhino.Inside.Tekla.
Unfortunately, I don’t have any Tekla license to check what’s going on. Can I download the trial version of Tekla and install Rhino.Inside.Tekla on it?
This shouldn’t be dependent on Tekla I think, the code doesn’t have any Tekla references. It’s just loading Rhino and Grasshopper in the background. Maybe it’s the way that’s done that’s different from how they do it in Rhino.Inside.Revit?
I’ve put the code snippet into this example project where there’s some boilerplate code to resolve the Rhino assemblies when the program is started (by the way, this resolve code does not get hit when the VisualARQ plugin is asked to load, so doesn’t seem to be anything to do with that).
Thank you gentlemen for your research. So at the moment it is not yet possible to use Visual ARQ components Inside.Tekla. I will hear when there is more news.
Is it possible with Visual ARQ to link many 2D drawings to a 3D model? Sometimes I have projects with almost 100 linked 2D drawings. In Tekla I can easily manage them with the document manager.
Is it possible to do this with Visual ARQ? It is for an environmental permit and all sections and views should be on a separate layout.
