I need to make a copy of a beam object in C# but everything that I have tried creates a block instance that is not a beam and the beam functionality is lost! Is there a way to copy beam objects and keep the beam functionality? Thanks
I also asked multiple times how to interact with VisualARQ objects (never tried myself) and never got an answer. At least the developer support seems not to exist: RhinoCommon: Interaction with Objects from for example VisualARQ?
Hi @patskorut,
Sorry for the late response, as I’ve been very busy with the release of VisualARQ 3 and fixing the serious errors reported.
Regarding your question: How are you creating a copy? In RhinoCommon, the best way to duplicate an object is to call the method RhinoDoc.Objects.Duplicate(). I haven’t tried myself, but I think this method should work with VisualARQ custom objects.
Regards,
Enric
Enric,
No problem, thanks for the reply that worked!!! I was a bit confused and was using GeometryBase duplicatedGeometry = rhinoObj.DuplicateGeometry(); which was copying the blockInstance so the beam functionality was getting lost.
I had another question, I am trying to apply some transforms to beam objects and can’t seem to get that to work either, Here is the code I am trying. Any help would be awesome. Thanks
Guid rhinoObjDupId = doc.Objects.Duplicate(rhinoObj);
RhinoObject duplicatedObject = doc.Objects.Find(rhinoObjDupId);
Transform translation = Transform.Translation(10, 12, 0);
duplicatedObject.Geometry.Transform(translation);
duplicatedObject.CommitChanges();
doc.Objects.Add(duplicatedObject.Geometry);
Hi @patskorut,
Try to use the RhinoDoc.Objects.Transform() method. This method can also duplicate and transform in a single operation, passing false
to the deleteOriginal
parameter.
Enric
