VisualARQ Grasshopper style alphanumeric properties
Is it possible to add alphanumeric properties in a VisualARQ style based on a Grasshopper definition that depend on the input parameters and update when the input parameters change?
Hello Charles,
You can use the Get Property component to obtain the values you are looking for and then update them using the Update Property component.
VA gh properties.gh (8.3 KB)
VA gh properties.3dm (2.7 MB)
Thank you ! can the Update Property component be activated programmatically instead of being activated by a mouse click on the Update button
Hi Charles,
Not for now, but I’ll add this feature to the wishlist. We are also working to allow creating parameters calculated from other parameters value, which might be what you need.
