VisualARQ 3’s imported doors and windows are not appearing in the top view. However, if I import the doors and windows using Grasshopper styles, they work correctly. The issue is that I don’t have scripts for all the doors.
test door.3dm (1004.2 KB)
Hi @uzairgulndm,
This door style doesn’t have any geometry defined for the Plan view:
How did you import the style? From a .val file?
vastyleimport
I don’t have the grasshopper file for this
can you please share all grasshopper file in one
if it possible for you
thanks
Hi @uzairgulndm,
You don’t need the Grasshopper Style for this, you can just edit the style after importing it:
thank you so much for the help
