VisualARQ 3.13 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.13 is scheduled for official release on
Wednesday, December 2th, 2026
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
List of changes since 3.13 RC1:
New Features (2)
- Attributes:
7840: Control the print width of hatch patterns
- Rhino 9:
16143: Support for named section styles
Changes (3)
- Interface:
16170: The isocurve density properties of products work as in Rhino
- Rhino 9:
16156: Support for the section style pattern print width of Rhino 916150: Support for the section style print width of Rhino 9
Fixed Errors (13)
- Constraints:
16168: Level constraints issue with walls intersecting with slabs16100: Constraints errors of walls with sub-levels
- DWG Export:
16160: Plan view with intermedium hidden levels is not exported properly to DWG16121: Dimension in the Model space is not exported to DWG16120: Text is exported rotated16119: Text is exported upside down to DWG15693: The line type scale for door openings has changed in the exported DWG file.15692: The stair section in the left Detail view appears differently in the exported DWG compared to the original Detail in Rhino.15690: The full layout is not being exported to the DWG file.
- Object:
16169: Products with a different isocurve density share the same block
- Object: Beam:
15456: Wrong beam length when it has an alignment offset
- Print:
16167: Columns are printed with an non-existing Solid section pattern
- Rhino 9:
16166: Section hatches are printed on VisualARQ objects with the Hatch scaling
Download links:
Previous version:
Enjoy!
