VisualARQ 3 Guides causing significant viewport lag in Rhino
Hi everyone!
I’ve noticed that using the Guides tool in VisualARQ 3 seems to significantly slow down the 3D viewport in Rhino.
While working on my model, the viewport became very sluggish, especially when navigating around in 3D. After some troubleshooting, I discovered that hiding the VisualARQ Guides immediately made the viewport much smoother and more responsive.
Has anyone else experienced this issue? I’m wondering if this is a known performance problem with VisualARQ 3 Guides or if there’s a way to optimize their display without having to hide them.
I hope this helps anyone experiencing similar viewport performance issues!
Thanks!
Hi @ion_pascari Thanks for reporting this issue. Which exact version of VisualARQ are you using? We encountered the same problem in earlier versions of VisualARQ 3, but it has since been fixed. If the issue persists in the current version (3.12), please share a file so we can investigate.
Hi! Thanks for your reply!
I believe I’m using the latest version of VisualARQ. I’ll also share the model with you so you can investigate the issue.
I had to delete much of the model to fit the 20MB limit. The lag is not as noticeable but it’s still annoying. At the original 100MB size, it made it impossible to work until hiding the guides.
HOTEL LAG.3dm (18.7 MB)
Hi @ion_pascari thanks for reporting this problem. We will investigate why the model runs slower when guides are visible. I’ll get back to you when we make it work better.
