VisualARQ 2.0.16 is now available for download.
This is a minor release that solves most of the issues reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
New features:
- Grasshopper Components:
- Added
Voids
parameter in theCustom Profile
component to create profiles with holes.- Added
Horizontal Alignment
parameter in theDeconstruct Door/Window
components.- Added
Height
parameter in theSpace Options
components.Changes:
- Parameters could be set using the display name, including spaces or non-alphanumeric characters.
- Improved speed when computing and drawing very dense hatches.
Fixed bugs:
- License:
- Validation (online and offline) failed when trying to validate using the same wizard that shows the “VisualARQ has expired” message.
- Invalid local licenses entered in Rhino Zoo Client were accepted in network mode.
- Zoo Plug-In now checks if the license is a valid VisualARQ 2 license before trying to validate it.
- IFC:
- Imported profile names are not changed unless they were anonymous.
- Fixed a crash when importing IFC files.
- Hidden Vector Output:
- Incorrect line width was used when printing.
- Document object was modified when baking a transformed referenced object.
- Plan Views:
- Removed overlapping curves of objects intersected by the level cut plane.
- Some edges of a gable roof didn’t use the right edge cut when the roof control points were modified.
- Doors and windows were misplaced after rotating the model.
- Selecting a plug-in material using the “Other…” option in the style editor didn’t work and “By Parent” was always automatically selected.
- Section curves of geometry inside blocks with a non-identity transformation were shown at a wrong position in plan viewports.
- Objects were not grouped when the “Quantity” field wasn’t the first field of the table.
- Annotation objects with the “Clipping” section attribute set to false may be hidden by coplanar geometry like slabs.
- Hatch in spaces with an elevation different than 0 were drawn in a reversed elevation.
- Fixed a crash when working in a Layout.
- Fixed a crash when trying to create a new group with geometry that had been undone.
Known bugs and limitations:
- Expressions in Grasshopper Params are ignored when displaying the value on VisualARQ properties panel.
- VisualARQ objects inside blocks or linked files are not shown correctly in plan and section views.
Enjoy!
Enric
