Visual glitch
A strange visual glitch on the cutting line of the clipping plane.
Thanks hesro, i was able to repeat RH-99539 Clipped render mesh offset from cut when zoomed
At first, I could see this ticket, but now I can’t.
I made it public again.
“zoomed in well beyond floating point precision. Similar issue to far from origin type situations”
I don’t know exactly what the term means, but this glitch occurs even if I don’t zoom in enough to fall below my file tolerance.
Regards.
Zoom far enough on anything its going to get wonky, but its just the render mesh not the actual geometry. This isn’t a bug per say, but a optimization we are constantly working on, hence the report.
The floating point errors on actual geometry typically come in when objects are extremely far from origin.
