Visual Arq
Hi! When will Visual Arkt become compatible with ShapeDiver.
We will evaluate the plugin as a whole for potential support in ShapeDiver, however it is very likely that several features will not be compatible with the cloud workflow. Could you maybe give some precisions about the use case you have in mind and which features you need to achieve it?
Haven’t tested Visual ark much, but I could think enough to be able to construct a house. Most important is the geometry of Walls, doors and windows. Option to change window and door, size and location, and move walls in shape diver.
