Visual ARQ Question - AISC Beam Shapes
Curious if standard steel shapes are included. I don’t have VA3 installed right now so easier to just ask :wink:
Hi @keithscadservices,
VisualARQ 2 already included the AISC standard column and beam profiles. You need to use any of the imperial VisualARQ templates.
You can also import the AISC styles to any document using the vaStylesImport. The .VAL file is in the folder:
C:\Program Files\AsuniCAD\VisualARQ 2\RHINO7\en-US\Libraries\Imperial\AISC.val
Enric
