Visible white edge (rim specular) on glossy render objects
I am running into an issue while trying to render glossy pots, once rendered there is a very visible white edge on the bottom of the pots. After some initial troubleshooting with the sheen settings, I still have the same result. I have toyed with lighting, and other settings but no change. The current material used is a PBR with bump and displacement files added.
System info: Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13002, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Stand-Alone
Apple macOS Version 15.2 (Build 24C101) (Physical RAM: 36GB)
Mac Model Identifier: Mac15,7
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M3 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSafariServices.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/vhgroupllc/Library/Application Support/McNeel/Rhinoceros/packages/8.0/keyshot_studio/1.7.1/libsceneapi_wrapper_rhino.dylib
/Users/vhgroupllc/Library/Application Support/McNeel/Rhinoceros/packages/8.0/keyshot_studio/1.7.1/KeyShotStudioRhino8Plugin.rhp “KeyShotStudioRhinoPlugin” 1.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.15.25019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.15.25019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.15.25019.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.15.25019.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.15.25019.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.15.25019.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.15.25019.13002
Screenshot of a material setup and raytrace mode to show white edges and file uploaded.
copypots.3dm.zip (17.3 MB)
That is the Fresnel Effect on the material based on the reflective and curved nature of the object. At the glancing angles is becomes highly reflective of the tabletop and background.
Making it less reflective or glossy will minimize this effect.
Also, you are using shadows-only groundplane, so the pots get also light from below.
Give the ground plane the default material and you’ll see that the light around the bottom edges disappear.
Thanks Scott and Nathan,
I was able to reduce the issue by adding walls around the objects to reduce the reflection and giving the ground plane the default material as per Nathan’s suggestion helped as well.
