Can anyone walk me through how to create a view style that is similar to Wireframe in layout, but shows only visible lines in the model? The issue I don’t know how to resolve is how to work around the additional lines that show up on the faces of a polysurface when in the “Wireframe” view mode that are not appropriate to a drawing. A simple example of this is an extruded cylinder that is represented by 3 parallel lines that run into top and bottom caps, with one of the lines running up the center of the cylinder (perspective view has an additional line).
I’d like to create a view mode for Layout that is similar to what I’d get in Make2d when generating only visible lines. Any help would be appreciated! Let me know if I can better clarify. Thanks.
