Visibility of objects created in Grasshopper within the Rhino 7 Windows
Hi there.
I have made a small discovery which I think centres a visibility problem we have with objects created in Grasshopper and visualised in Rhino 7. It is we presume in the mix of settings for Rhino 7 that we have created in running through the standard install, and the use of LadyBug Tools v1.3 plugins for Grasshopper. This happens on a whole bunch of student lab computers. I have created a small animated visualisation to show what we encounter.
Essentially, the LBT 1.3 script creates all the input geometry, runs the analyses and outputs the graphics to Rhino 7. In this situation, controlling what we see in the standard Rhino ports is something over which we have limited control. Sometimes they are there. Sometimes not. When we first run LBT 1.3, not.
The script has a bunch of model visualisation tools provided to help the users visualise the model prior to running the model (e.g. a graphic representation of the rooms and their R-values). Turning these on and off seems to trigger the visualisation of the other objects. But even this is not reliable. Zooming in and out amongst the various graphics produces oddly variable visibility.
In the past 24 hours, we have discovered an apparent cure: draw any object in the Rhino window. All the objects appear AND zooming in an out has no effect on visibility.
I have created a youtube demonstration of the phenomenon (not a solution, but a way of working around the issue, so if this provides insights into what Rhino settings we need to change, I would be ever so grateful):
Hi Michael -
I’m afraid a video doesn’t help me much - I’ll need the information as requested here:
That is, a gh file without any LBT components and the SystemInfo from one of the computers this behavior is occurring on.
Possibly this should be[Visibility of Objects when I zoom](Possibly to be found under: Things disappear when I zoom in closer - #10 by nathanletwory) be found under:
Kia ora Wim
I seem to have identified this as a generic visibility issue in Rhino 7. I have just imported an fbx file into Rhino and have the same visibility issues.
If I zoom into the perspective model, the models disappear…
Basic model in first picture. Second picture shows zooming in orthogonal views seems to function well, but in perspective top fight model has half-disappeared due to some camera clip function over which I seem to have no control. One more click forward of the scroll wheel and the whole model disappears…
Hi Michael -
Without the actual 3dm file, there is not much debugging that can be done here…
And, as requested before, please post the SystemInfo.
Kia ora Wim
Just returned to this forum from a long absence avoiding this problem with various workarounds, and noted this is incomplete.
The SystemInfo requested on November 21 was posted here on September 21:
Please note the most recent example in this stream used an imported fbx file that is from a source from whom I may not share the original file. My apologies if this was not clear. I was hoping that there might be a generic issue that I was missing about perhaps clipping planes and imported files - or some kind of import scaling issue that I was unaware of…
M
Hi Michael -
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001,
Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Educational Lab License, build 2021-08-10
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP (Hosting Remote Desktop session)
I really hope that you are not still running Rhino 7 SR9!
Apart from that, Remote Desktop is not a supported configuration - Rhino - System Requirements
Ah, interesting. We use Remote Desktop to run lectures from rooms where the display computers are not as capable as the students’ or my desktop. However, as the problem occurs consistently on whichever computer configuration I have, it had not occurred to me to do anything than log in to the wrok/school computer to report the issue. The desktop for the continuing problem has the following Sysinfo report
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Educational Lab License, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro K1200 (NVidia) Memory: 4GB, Driver date: 5-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2021
Driver Version: 27.21.14.6296
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.36.135\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.36.135.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.3.3\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.3.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
Thanks, Michael -
There are situations where the camera’s near and far clipping planes can cause some geometry to be clipped. You could use the Camera command to try to troubleshoot this, but if you want us to be able to say anything meaningful about this, pictures nor videos will do any good and we’ll need actual Grasshopper or Rhino files.
A post was split to a new topic: Colibri not saving images
