Visibility Attributes (Visibility) Example
Hi,Visibility Attributes is one of the new components within Object Attributes (Rhino - Object Attributes in Grasshopper) I am trying to use the former together with Query pages. The goal is to have a bunch of Object, but I wnat to manually define wich of the Objects (or Blocks) are displayed in which of of my layouts. Can someone please show an example of how this is supposed to work? I tried to use a boolean pattern in each path, but it seems wrong. Thanks!
Maybe I am getting this wrong and Visibilty can only be defined globally, but then what is the purpose of Pages as an input?
I have the same question, this page feature doesn’t seem to do anything.I know that in theory, rhino8 should control visibility on every detailview, not on page layout, but the visibility here can not be defined to detailview. I think this is a bug, and I look forward to the official update as soon as possible.
@phillip
I could solve it. It is a little confusing, because even though it is called “visibility” it is not what it does, but it controls where you really draw the things. Meaning, you are directly drawing inside a layout. So I intended to draw things in my scene and have them visible in a layout, which already seems weird to be possible. Nevertheless the essential component for this is “Make2d” and it is not in the Rhino tab, but in Visibility>Dimensions. Some example files would be nice for all the components in the Rhino tab, so it would be easier to find out how they work.
