You can run a virtual compression test using Intact.Simulation for Rhino Grasshopper to explore vast design spaces. This helps you iterate on better designs, save the cost of physical testing and simulate without the meshing and pre-processing bottleneck. Better yet, the workflow can be automated to run 100s of simulations. Intact.Simulation for Grasshopper is a meshfree FEA simulation software. Drop an email to info@intact-solutions.com if you want the workflow!
You can download Intact.Simulation in Food4Rhino: Intact.Simulation for Rhino Grasshopper | Food4Rhino
