… stop reacting to mouse input - for instance rotating the view by dragging the RMB or zooming with the scroll wheel. When this happens the OSNAPS doesn’t work either…
Systeminfo_MacBook Pro.txt (5.1 KB)
Hi Philip -
Do you typically work in a single specific file all day and several days in a row, or do you see this happening in any file. Does it mostly happen after some time or after using specific commands?
When that happens, how do you get out of that state?
Hi Wim
Usually yes.
Yes.
That’s a tough question… However, I forgot to mention in my original post, that it usually happens in only one viewport at a time, so I try to maximise and/or minimise the viewport, switch viewport, zoom in and out and trying a bunch of different things… Eventually it gets out of that state, but I can’t recall what specific action helped, sorry. I’ll try to remember to pay attention, when it happens next time…
Hmmm… I was wrong. It can happen in all viewports at once. The osnap-thing just happened again. I started the line command (l = ! _Line) and I couldn’t snap to anything. View manipulation did work though, so not reacting to mouse input doesn’t seem to be related to osnaps - but both can obviously happen at the same time…
Now I got out of the state by switching to Safari and back again.
