Hi guys,
I have just moved over to a UHD 2560x1440 screen at home and a 4K at work, and one thing that I now would need is an override to set a custom resolution for the viewport.
A 4K monitor is 4x the amount of pixles than FullHD and that requires LOTS of horsepower. So I would like a 1/2 button to toggle on and off, and / or a dynamic swap to half res (or lower) and then back when still.
Ah, sorry, yes I know I can set the size of the viewport, but what I am talking about is setting the resolution. In the same way we can set the monitor to run at native resolution or a set of lower resolutions, so that is what i am talking about.
Or said differently:
If I need to evaluate the feel of a concept then I want to view it in full screen, at a good frame rate, but I donāt need retina resolution. So full HD on a 4k monitor could do just fine. But maybe only for the perspective view. And if could swap to full resolution if not manipulated then that would be even greater!
Is it more clear now?
Thanks for the link⦠I canāt say where this would fall in terms of priority given the other display work but maybe it could be a plugin or script. Have you tried to write it?
As long as all you want to do is go down in resolution, then this should be pretty brain dead simple⦠However, if you then come back and say you want to render in higher resolutions (than that of current viewport), then Iāll tell you to go pound sand
I donāt think allowing you to specify any arbitrary resolution would be a good idea⦠It should always be a factor based on the current viewport in which youāre rendering. Your idea of a āhalf buttonā is a good one. Otherwise you run into aspect ratio issues and skewing and stretchingā¦because the end result will still need to be displayed in the full res viewport (thereās nothing you can do about that, hence my sand pounding reference above ;-))ā¦which means pixels will be stretched to fit⦠So if the process is simply an even factor of the current viewport (i.e. 0.5, 0.25), then I can guarantee proper pixel scaling/stretching and placement, and there wonāt be any kind of āpixel driftā.
I think this can probably be done pretty easily and quickly in a plugin⦠Maybe Iāll try something over the weekend.
Hi⦠Just to add my -1.9cents. I thought that perhaps a quick option would be to make a View Mode with View Scaling (Under Other Settings) set to 2 for Vertical and Horizontal, but this only changes the scale of the viewport, not the resolution.
It might however be a quick option for your quick zoom to set a hotkey to quickly jump back and forth between your normal and 2x view mode though? Michael VS
If Iām interpreting correctly, KeyShot for Mac OS has a similar feature called - āRetina button.ā
So, if one is rendering @ 1920 x 1080, the window will be super small on a 4-5k without using the Retina button (2x), or, conversely without a Retina button, if the window is āsized upā to fill the 4 or 5k screen (for visibility/visualization purposes even if still rendering at 1920 x 1080), when the file is saved, the window opens super big when moving the file to a low res screen. This sounds like you?
I just realized that clippingplanes are one of the items that really slowing things down when the resolution goes up.
Shaded, rendered and pen mode are all super sluggish on high res, but it is not affecting wireframe speed at all.
@jeff do you know what causes that? Is it a per-pixle-calculation going on that affects rendered polygons only?
I know nothing of Rhino internals, but from other 3d work, wireframe typically only calculates/draws the pixels on the edges, while others draw the faces as well. that takes a ton longer. drawing the background isnāt as expensive.
