Viewport properties gone
Hi, ViewportProperties seems to have gone MIA. How do I set view projection to parallel?
Thanks
Eric
This is controlled in the Properties panel when the viewport is active and you have nothing selected… --Mitch
Got it, thanks.
Eric
@pascal As a note to the developers, one “collateral damage” is that it’s no longer possible to change the viewport projection with objects selected. So if you have set up a complex selection set, and you want to change from perspective to parallel, you will lose it. An “edge case” to be sure, but perhaps not all that rare…
And the viewport properties entry is still in the viewport menu as well as the view menus, for the moment they don’t do anything except open the Properties tab (if it’s not already showing) and of course unselect anything you have selected…
ViewPort Properties being in the viewport menu is what led me astray.
Eric
Hi All,
I am not sure if this is the correct thread for the camera settings.
In Rhino 7 WIP, despite not having anything selected, the “View properties” gives me a blank space and I cannot change any setting. I attach screenshot.
Thanks
Luca
@luca_biselli check here
Thanks very much.
All working now.
Luca
