When trying to open viewport properties in 7.7.21160.05002, 2021-06-09 it opens the object properties panel instead. This makes it hard to adjust things like field of view of the camera etc. Typing the command ‘viewportproperties’ has the same result.
Hello - with no selection, object Properties should show the viewport info. You can get at the controls at the command line as well with
-ViewportProperties
(dash in front)
Does that help at all?
Having quit and restarted rhino, it is working as expected. Still, it is a weird bug and seemingly intermittent bug.
