hi @m.oguz this is a file setting, not a system setting or Window Layout setting. So once you made the changes, you need to save it as a template file.
You can use the SaveAsTemplate command to save your current file in the default Templates folder. Other than that, you can always just save a file anywhere that is convenient to you and make it a start-up template in the Rhino Options.
