I have noticed the some jerks (dashes) in Rhino WIP (what is never in Rhino 7 or 6). For example, when I use the Point Set Deviation tool and peek inside a geometry. Try it, please.
Test.3dm (1.5 MB)
I do not support the Russia.
Test.3dm (1.5 MB)
please run the systeminfo command in rhino and paste the result here.
FWIW: I don’t see this. Works smoothly with that model and settings.
Rhino 8 SR0 2023-1-10 (Rhino WIP, 8.0.23010.12305, Git hash:master @ 11f0f80af7d8c8b84087583e5b1f98523fb16dad)
License type: Corporate, build 2023-01-10
License details: Stand-Alone
Expires on: 2023-02-24
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 3.8Gb)
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9079
Primary OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-11-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9079
> Integrated (slow!) graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9079
Driver Date: 12-11-2020
Driver Version: 27.20.100.9079
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.23010.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
This is odd, not mentioning the Corporate version, it appears you have two UHD Primary cards? did you miss copy the text? Where is the actual video card?
Please purchase a legit license. The bar for the educational is pretty low and you can use it commercially.
I have no idea. I was working the other day and then Rhino 8 was beginning to work slowly and progressively until program crash.
I have used the Copy button just. That is right.
In Russia? I can’t buy as yet.
Noticed that. Just take care of it when you can.
I would be shocked if you’ve been able to work in the WIP in Rhino 8 with UHD Graphics Memory: 1GB card. Did your video card die?
Surely!
But I worked in Rhino 7 on this laptop and that was fine. I do not have the video card.
