I am trying to determine the existing setting of a viewport via the below method (which works in c# windows) but have found that no values are returned when the same code is executed on a mac. (ie. all processes halt when executing the method in a successfully compiled mac plugin).
I have isolated the problem to this line.
String displaymode_this = doc_actual.Views.ActiveView.ActiveViewport.DisplayMode.EnglishName;
Notes:
I believe that I understand the differences in use of ‘doc’ from windows to mac environments - but maybe not!
doc_actual is my own class level variable used to capture the incoming doc from RunCommand for reuse in a series of functions.
I’ve tried other variations of the method in lieu of the failing line - also without luck. (ie. String test_this = Rhino.RhinoDoc.ActiveDoc.Views.ActiveView.ActiveViewport.DisplayMode.EnglishName;)
Below is a more complete view of the function / code that fails at the above mentioned line.
public void findDisplayMode() { DisplayModeDescription[] displaymodes_types = DisplayModeDescription.GetDisplayModes(); Int32 display_modes_count = displaymodes_types.Length; String[] displaymodes_english = new String[display_modes_count]; for (int i = 0; i < display_modes_count; i++) { displaymodes_english[i] = displaymodes_types[i].EnglishName; } Int32 displayMode_index = 0; // Code works up until the next line - then it halts. String displaymode_this = doc_actual.Views.ActiveView.ActiveViewport.DisplayMode.EnglishName; for (int i = 0; i < display_modes_count; i++) { if (displaymodes_english[i].Equals(displaymode_this)) { displayMode_index = i; } } // use of displayMode_index removed for example. }
