Viewport Capture to File fail
Hello all,
I’m having trouble capturing the raytraced viewport in WIP 7.0.19274.12465. I can assign materials just fine and the raytraced render looks good, but as soon as I run ViewCaptureToFile, it seems to kill the raytracing and go back to the “rendered” view. I did not have this problem in the previous WIP version. Is this happening to anyone else?
Does this happen also with the dashed version of the command?
No it does not. The dashed version saves the raytraced version.
ok, at least you are able to continue. Thanks for reporting.
I figured out what the problem is. I’ve logged a bug for @stevebaer ( RH-55350 )
Great! Thanks Nathan!
