I keep forgetting how to set the dimensions of the output. There is an underscore here but don’t remember where…help.
Hi Paul,
try _-ViewCaptureToFile then after the file name has been set using a path or using the browse option, you can define the size from the commandline.
c.
Thanks…yes, just figured it out. I keep forgetting the exact command line.
Seems the size definition is broken. I get the right size but the transparent grey frame is is not accurate. In Brazil with safe frame turned on…the safe frame goes off considerably.
Hi Paul and @Pascal,
just reproduced one related anomaly here using Rhino renderer as current renderengine. If the Save Frame is enabled in a maximized viewport and i capture the viewport using _ViewCaptureToFile, after setting Scale=2 this is the result i got:
I get a 4 Save Frame overlay of my captured viewport. This does not happen if the viewport is not maximized.
thanks,
c.
Confirmed:
-Willem
Got it, thanks.
Bug track item-
http://mcneel.myjetbrains.com/youtrack/issue/RH-22583
Not visible to the public yet.
