ViewCaptureToFile via Python Script
is it possible to run the ViewCaptureToFile command from within a Python script?
Thanks
(written from memory, so double check)
import RhinoScriptSyntax as rs
filename=filelocation+filename+extension # you need a location and a filename
rs.Command("-ViewCaptureToFile "+str(filename) +" _Width 1920 _Height 1080 _Enter")
You can add the more info to it as you please
Thanks, works perfectly.
