Suddenly ViewCaptureToFile not working. When I type in command pop up menu doesn’t appear.
ViewCaptureToClipboard is still working.
_ViewCaptureToFile is not working also.
Hello - just to be sure, can you try with the “-” version of the command? The dash in front
-ViewCaptureToFile
should run the command with no dialog box.
Does that work?
No, nothing happens.
2 weeks ago it was freezing up my machine to where I had to end task and restart Rhino. It did it twice. Haven’t bothered using it since.—-Mark
Can you please run the SystemInfo
command in Rhino and copy/paste the results here?
I downloaded Rhino 7 and everything is working fine…
