How can I control the JPG compression quality in WIP - right now the captured images over here are very compressed/grainy (looks like level 5) - and I don’t see anywhere an option to change it. Never had such issue in V5.
Also on another small thing for this command - would it be reasonable for the scripted version to remember the last used resolution setting like the UI one does ?
This might not have anything to do with compression… What happens if you try saving as a PNG file? That’s a lossless compression, so everything should look fine. If it doesn’t, then there’s a problem with how we’re capturing the image.
Setting the quality vs compression depends on the image itself and level of detail, so it is tricky to set automatically. I will set up the capture of JPG to the 99% quality in the next WIP (to match what we have in V5).
Following are three images at different quality/size.
Thanks @raja (and sorry about getting back to you so late).
I think this is a good setting - we can always save as more compressed JPG later on if needed, but there is no other way if the saved file was very compressed. So almost no compression is a very good solution I think. Thanks for fixing it!
