I have one 3dm file by hand, and have set the locally debug environment. Language im using is Python.
Question: How could I achieve the similar effect of ‘ViewCaptureToFile’ through the pure code way?
Assumed Steps: Readfile-- SetView-- ViewToBitmap (I saw these in RhinoCommon API, but not in Rhino3dm or the Rhino_Compute documentation or repos… so kind get stuck)
I tried to achieve this effect in the gh context, and it works. But I DO want to get rid of the gh file, and can run it directly from the console or python prompt window.
So as you can see in the gh file, I add the Get_XXX component new in Rhi8. However, when I run it together with the codes below in the locally debugging environment, it fails.
