Hello
I ram having difficulty with a re-installation of Rhino 4.0. I recently had to have my computer re-formatted due to an unfortunate Windows update and when I re-install Rhino 4.0 which had been working, I developed the following issues:
My mouse wheel which I use to for dynamic scrolling only works until I select any operation in any particular view port. If I pan, or tilt or select an object the scroll wheel no longer works.
When I select an object, I need to manually pan the view port in order for the object to become active (yellow line in the case of curves). I then need to manually pan the other three view ports to have them update. I even have to pan the view port to use the ESC key to deselect an object or operation.
If anyone had any thoughts I would greatly appreciate the help.
I am using an Alienware Laptop with a GeForce GTX 970M video card. I am running Windows 10.
I have re-installed Rhino in Safemode with no luck. I am using the most current Rhino 4 update.
Thank you for your help
Ben
