View names changing oddity
I have this weird phenomenon. I normally work in a 4(+)view mode, and I’m just doing modeling stuff, rotating the perspective, swapping view modes, toggling clipping planes, not manipulating the viewports any other way like using saved views or changing the CPlanes, and then I notice all of a sudden that some of the viewports have been renamed. “Perspective” is now “Top,” everything is called “Right,” that sort of thing. I look through the command history and don’t see any clues. I can’t repeat it, but it seems to happen to most files eventually.
are you modeling like this? i am doing some rhino for a couple of hours i can keep a lookout
Basically yes…
Hi Jim -
I can’t say I’ve seen this…
This is definitely still happening in the WIP.
This still happens to just about every file eventually.
