View capture to file/clipboard doesn’t work properly when scaling the size. The output image is cropped and split into a grid. Without scaling works fine. Any ideas what is wrong or it’s just a bug?
Hello -
Please run the SystemInfo
command in Rhino and copy/paste the results here.
Rhino 7 SR0 2020-8-18 (Public Build, 7.0.20231.16016, Git hash:master @ 58f0ee664bd3c34b972266f3f3bdb1de4c3bebcf)
License type: Commercial, build 2020-08-18
License details: Cloud Zoo
Expires on: 2020-10-02
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G5033) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro10,1
Language: en-PL (MacOS default)
NVIDIA GeForce GT 650M OpenGL Engine (OpenGL ver:4.1 NVIDIA-12.0.24 355.11.10.50.10.103)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1 GB
Graphics: NVIDIA GeForce GT 650M
Displays: Color LCD (221dpi 2x)
Graphics processors
Intel HD Graphics 4000 (1536 MB)
NVIDIA GeForce GT 650M (1 GB)
Color LCD (1440 x 900)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
Unknown:
Third party kernel extensions
com.bitgapp.eqMacDriver (1.5.2) 7FF03650-6287-37A9-B143-66F52FC42035
com.eset.kext.esets-kac (680.00.10f01) 37A62525-5F6A-3E1A-991F-12495360230D
com.eset.kext.esets-pfw (680.00.10f01) F291D244-2D7B-3762-B307-523440C3C306
Third party plugins
/Users/janlibera/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris/Iris.OSX.rhp “Iris” 1.0.0.0
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20231.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20231.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20231.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20231.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20231.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshUtilities.rhp “MeshUtilities” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20231.16016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20231.16016
By the way, I have also problem with grasshopper, which crashes immediately when launching. I already wrote about it in other post.
Hello - Your mac is pretty old, as these things go, 2012, is that correct? - if so, I suspect the video card is not up to the task for the View capture stuff. @John_Brock - do you have an idea if that might be the thing?
The crash is related to running on Mojave. Curtis is looking into a fix for this
Mojave is a problem and yes, the old Nvidia GeForce video was great back in the day, but Apple has really dropped the ball on support for them.
In fact, even on the new Macs, you can get a fast graphics card.
About the only option is to use one of the external graphics boxes and put a fast AMD car in it.
It’s time to hold a retirement party for your old GeForce Mac.
Thanks,
The question is why it works properly with Rhino 6?
It’s such a shame, that they stop supporting Nvidia I think it’s time to say goodbye to apple.
