[VIDEO] Build a Topographic Base and Road in Rhino - Using only 3 Curves?
Is a complex landform and road possible with only three curves? Yes! In this video you will learn how to
  • Build from curves,
  • Make overlapping surfaces bigger than needed and finally,
  • Use Prof-3D-Dave’s patented Split-Split-Toss technique.
This method will generate clean and closed geometry every time. Guaranteed. Wow.
