I finally managed to replicate the crash. You can see the video with all the steps taken from a newly opened file here: Screen Recording
I also attach the SystemInfo and the image I referenced in the video, in case it has anything to do with it.
Just try:
Open Rhino 7
make a curve (about 6 points) in top view
select curve with automatic points on
move some point
press Ctrl+Z => here is delay about 2 sec. only for firts “undo” use
every other moves and undo will be normal
If you wanna try again, close Rhino a run new.
Sorry - yes, it’s not in the release candidate. If you would like a build with the fix, please DM me. But note that there may be other issues with these bleeding edge builds. Otherwise, it will be in 7.6 RC1
Any idea when this will be fixed? I’ve had to revert back to Rhino 6 in the meantime because I waste so much time waiting for the undo command to work.
Hello, has this fix been implemented? I’m using Rhino 7 on Windows and still experiencing extremely long “undo” times. I’m on 7.13, currently upgrading to 7.14 and hoping that will resolve the issue. I’ve had to quit and lose a few minutes of work multiple times, since I was being reckless and not saving before pressing Ctrl+Z. I feel like in previous versions I could rely on the undo function to work extremely quickly and may have picked up some bad habits.
