Hi guys,
I am an architecture student who is getting used to Rhino and I have a very basic question about trimming: suppose you have a polygon or an open polyline composed of several segments, is there a way to cut one of thesides or segments without havving a reference line? I am thinking commands like Cut on Archicad or Autocad.
If it’s a full segment of a polyline or polycurve (from one vertex to another), you can sub-object select the segment(s) with Ctrl+Shift+click and then hit the Delete button.
If you wish to trim at arbitrary locations, then your alternatives are three:
Draw a cutter and use that to trim
Use Split>Point and pick one or more points to split the curve at (minimum two for closed curves), then delete the split part(s) you don’t want.
