Attached is a bad curve from a file a client sent me…Very bad curve. In addition to being invalid, if you try running SimplifyCrv on it, Rhino crashes (both V5 and V6). CurveBoolean crashes as well. Explode will not explode it, most commands don’t work on it. If you Extrude it - which seems to work miraculously - and explode the result, you see the problem - overlapping segments in the original.
Trying to find out. For the moment it might have come from a CurveBoolean involving some imported curves… that’s all the info I have, I asked the client if he could create a recipe for cooking this one. --Mitch
