Very Basic Trim Problem
I had a problem trimming a surface, and when I isolated the problem, it is surprisingly basic (see attached file) – I have a simple revolved surface, and when I try to trim it with a plane, it fails in both Rhino 5 (Windows and Mac) and Rhino 6 (Mac).
Trim_Problem.3dm (3.0 MB) (Rhino 6 version)
Changing the tolerance, even to extreme values, doesn’t help.
Running Intersect makes the problem a bit clearer:
– Rhino is getting the intersection between these surfaces very wrong for some reason.
In this particular case I will probably just find a workaround, but it seems surprising that this would happen in such a simple situation. It would be good to understand exactly what is giving Rhino difficulties here, as it might help to understand more complicated trim / intersection problems in the future!
Hello - try InsertKnot > Automatic a couple of times in the U direction (knots go ‘around’). Then trim.
I’ll get this example onto the pile.
https://mcneel.myjetbrains.com/youtrack/users/f0b71a1c-4a96-46ef-8f2e-8617240286d3
Hello , bobtato
The V direction is in degree 4>
If you rebuild your surface in degree 3 like in my exemple, you will be able to trim it.
I hope it help.
Sylvain
Hello - keep in mind that Rebuild does not preserve the shape of the input, while InsertKnot does.
Yes it s true i should have precise it.
It s because i have less problemes with degree 3 than with degree 2, 4.
I often rebuild before triming or booleen operations.
But InsertKnot is the precise way to do it.
Thanks @pascalInsertKnot resolved the problem!
It is useful to know that this command preserves the exact form of the surface – it isn’t important in the simplified example, but of course my real model is more complicated and involves trims and joins that would break if I used something like Rebuild
