Vertical Sky Component Honeybee - Result greater than 40%
I appear to be getting a reading of approx 49% when I carry out VSC analysis of a point placed in the centre of a window.
The result should have a maximum value of 40% (according to BRE guidelines).
I believe I have set up the file correctly and do not receive any errors.
Any help would be greatly appreciated!
Thanks,
Richard
Hi Richard - you have better chances of getting an answer if you ask your questions on the forum that is dedicated to LB|HB - https://discourse.ladybug.tools/
Note, for someone to be able to help you, you should post the gh file with all Rhino geometry internalized.
