Thanks a lot for this plugin.
I installed the windows version since the mac version did not work with my rhino 5.
I got less errors , but I still have one:
Is it possible to solve?
I think this is the last version that works for rhino 5 mac… not all the components function however: https://aws1.discourse-cdn.com/mcneel/uploads/default/original/3X/1/0/10e7fe606b5e6d7248f467146e49ecfb6da707df.gha
unfortunately the component not working “bake” is the one I need to get the outcome:
Thanks anyways!
Human.gha (414 KB)
This version (I think it’s the same one I posted above!) works fine in Rhino 5 for mac — Bake geometry loads no problem:
What version of Rhino 5 mac are you using?
5.5.3 Version
Then try the one I just uploaded. I would be very surprised if this error still occurred since I have no trouble with it in the same version.
Actually you are right. The error had to do that I was opening a file coming from another user forum. I look for the component in my version and just added again. Thanks so much for your fast response.
