Verbose Check for Updates
Why is Check for Updates so verbose?
To me, it doesn’t make sense to have this novel.
The same is seen in other situations, e.g. Units from the status bar:
Edit Display Settings is calm, and feels clean:
In Rhino the commandline needs access to all the settings in the command. In this case, that means all the options and the suboptions they contain. This can make the commandline itself overwhelming in those cases.
We expect most of the time these commands will be used by scripts and not necessarily human interactions.
What did you wan to use the output for?
A technical argument.
From the users view it’s only verbal clutter.
Example:
_DocumentPropertiesPage
Opens the document properties in the last used section.
And does not list the choices.
_DocumentPropertiesPage _units
Open the units section.
Why list all the other choices?
Even the annotation styles of blocks…
Useless clutter without any function.
Feels like a debug output.
Why not like this for a right click in the units section in the statusbar:
_noecho
Cosmetics, I know.
No scripts involved, only Rhino UI.
I believe you understood exactly what I was trying to express.
Now I wonder why you ask this question.
Yes, I guess I do not understand exactly yet.
I thought you were talking about the commandline clutter that comes with the initial levels of the Options pages:
It has changed as we roll out more menus.
Or is this about the layout of the Check for Updates dialog itself?
Next try…
I start a command from the UI by mouse click, as an example Units from the statusbar context menu.
This brings me to the Options - Units.
Expected.
I find it irritating that all possible choices of _DocumentPropertiesPage are listed in the command area.
That is absolutely useless.
It fills the command history with jive.
Try yourself:
_noecho
This avoids the jive and makes a clean impression.
Spills jive to the command area without any purpose.
What is the listing of all the options good for?
Are you pleased with the unnecessary clutter?
Ahh, ok, now I see what you are looking at an how to create it. Thank you for the detailed steps.
I will get this looked at. I think the status bar menus need some no echo added in the right places.
