I’m having a strange issue with Veesus Point Clouds for Rhino and I’m wondering if anyone else can reproduce it.
I used Veesus in Rhino years ago and, as far as I remember, I could display the streamed point clouds normally in both Perspective and orthographic/Parallel views.
For quite some time now, however, point clouds are displayed correctly only when the viewport projection is set to Perspective.
If I use a standard Top/Front/Right viewport with Parallel projection, Veesus displays only a very sparse set of points, almost as if it is loading only the coarsest LOD of the VPC.
The interesting part is that I can reproduce it simply by changing the projection of the same viewport:
Perspective → full-density point cloud displays normally
Parallel → only a very sparse point cloud is displayed
I have already tested the following:
Maximum Veesus Quality, Filling and Point Size – no difference.
GPU Tessellation enabled.
Different OpenGL settings.
Rhino 8 and Rhino 9 – same behavior.
Another computer/user – same behavior.
Point clouds originally use large survey coordinates (around E=261,000 / N=4,201,000), but I also used the Veesus alignment/origin tools to bring the cloud close to 0,0,0 – exactly the same problem.
Restarting Rhino after changing graphics settings – no difference.
So it does not appear to be related to large coordinates, a particular Rhino version, or my computer/GPU.
The cloud itself is clearly loaded in the Parallel viewport, but Veesus seems to select an extremely low-density representation. Switching that viewport back to Perspective immediately causes the full cloud to appear.
Can anyone using Veesus Point Clouds for Rhino test this?
In particular, could you load a VPC, go to Top view → Parallel, and compare it with the same view after changing Projection → Perspective?
I’d also be interested to know if this is a known Veesus/XStreamEngine issue, or if there is some setting affecting LOD calculation in Parallel projection that I have forgotten about.
Thanks.
