Vectorize Crashes Rhino 8
Hello
I wanted to test Vectorize plugin from @dale on Rhino 8, it works well but if I play a bit to much on slider it crashes Rhino. Here an image I use for Comparison with Image Thinner (Nautilus plugin).
WXkRR_smooth
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commerciale, build 2023-11-21
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.1
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 3-28-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.89
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-28-2023
Driver Version: 31.0.15.2889
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\LaurentDelrieu\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Grasshopper2\2.0.8715-wip.22923\Grasshopper2Plugin.rhp “Grasshopper2” 2.0.8715.22923
C:\Program Files\Geometry Gym\Rhino8\BullAnt.rhp “bullant” 1.5.6.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
Hi Laurent -
Can you confirm that the Rhino crash reporter doesn’t pop up when this happens?
Apart from that, this is a know issue → RH-77301 Vectorize: Crashes Rhino 8
Hi
Yes I confirm no Rhino crash reporter
I’m experiencing similar behavior. Moving the sliders is sluggish, then eventually crashes without crash report popup.
Rhino 8 SR5 2024-2-15 (Rhino 8, 8.5.24046.03001, Git hash:master @ e8229c556c788288cab06127611336f1d7162c19)
License type: Commercial, build 2024-02-15
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.7
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA RTX A1000 6GB Laptop GPU (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24046.3001
Hi @jcparks,
Can you provide me an image to test with?
Thanks,
– Dale
Hi @laurent_delrieu, @jcparks,
I’ve pushed version 8.4 of Vectorize up to the 'PackageManager`. Nothing new, just stability fixes.
Please test at your convenience.
Thanks,
– Dale
