Vector Print Issues
Experiencing issues with printing in Vector mode. In these example files, the pickets are not reliably rendered properly. Notes below:
Attaching the following files:
VectorPrintBug_Vector_Floor.pdf - All but 5 pickets are missing 2 lines. Layer “Floor” is on. This file was saved as “Vector”.
VectorPrintBug_Vector_NoFloor.pdf - All pickets are rendered properly. Layer “Floor” is off. This file was saved as “Vector”.
VectorPrintBug_Raster.pdf - All pickets are rendered properly. Layer “Floor” is on. This file was saved as “Raster”.
Original Rhino file and system info also attached. Thanks!
VectorPrintBug.3dm (1.0 MB)
VectorPrintBug_Vector_NoFloor.pdf (5.9 KB)
VectorPrintBug_Vector_Floor.pdf (6.3 KB)
VectorPrintBug_Raster.pdf (697.5 KB)
sysinfo.txt (7.0 KB)
Hi Kaleb,
Here is a vector pdf generated in 9.0.26197.00304 on a similar mac setup (sans the block edit plugin)
Can we get a screenshot of you Print dialog as well?
Page 1.pdf (7.5 KB)
Hi Japhy,
That file magically fixed itself. Here’s a new version where I was able to more or less recreate the problem.
VectorPrintBug.3dm (750.5 KB)
Page 1.pdf (12.0 KB)
