I noticed an issue when printing a Layout to PDF using Vector Output.
Dashed linetypes display correctly in both Model Space and Layout, but they are printed as continuous lines in the resulting PDF.
Steps to reproduce:
- Create a curve and assign the standard Dashed linetype.
- Create a Layout / Detail where the dashed line displays correctly.
- Print using Rhino PDF → Vector Output.
- Use Match viewport display for linetypes.
Dashed linetypes display correctly in the Layout, but become continuous when printing with Rhino PDF → Vector Output.
Match viewport display is enabled.
The same Layout prints correctly with Raster Output.
This happens with regular Rhino curves as well as VisualARQ grid axes.
Layout — expected:
I attached the PDF generated with Rhino PDF
I can reproduce the same issue in both Rhino 8 and Rhino 9 WIP.
Is this a known issue with vector printing?
Page 5.pdf (757.4 KB)
