Vector gradients appearing on most surfaces when working in un-rendered shade only mode
I’m getting vector gradients appearing on all my waffle structure models this week that are supposedly in shade only un rendered display modes. They were all flat color last month. Not sure if this is a bug or something happening that is a default feature in the new version. Is there a way to change it back to flat surface colors only?
Thanks in advance for any info
Hi benblatt- there is an environment map in the shaded display mode, as far as I can see that is what you’re image shows. You can edit the modes in Preferences>Display modes.
Dear Pascal,
Thank you so much for your response. Yes it turns out my object shading was
set to custom and at 50% glossy. Not sure if this was the default on the
newest version or if i had somehow set it to that in my display
preferences. Thank you for your time on this. I really appreciate it.
Best,
Ben Blatt
