I thought maybe if i could grab the second line of the log that states the full path has opened successfully and copy and paste that. But i haven’t found any Rhino commands to be able to script that.
Could you give me a quick example of what you’re saying?
This is what i have so far. Just missing that filename!
Option Explicit
Sub Location
On Error Resume Next
Dim FileLocation
FileLocation = FileName
End Sub
Function FileName
Dim strPath, arrPoint
StrPath = Rhino.WorkingFolder & Rhino.DocumentName
If IsNull (Rhino.DocumentName) Then
arrPoint = Rhino.GetPoint("Pick Insertion Point")
IsArray (arrPoint)
Rhino.AddText strPath & "Main STP File", arrPoint, 5,,1
Else
End If
arrPoint = Rhino.GetPoint ("Pick Insertion Point")
IsArray(arrPoint)
Rhino.AddText strPath, arrPoint, 5,,1
MsgBox "Disclaimer: If this is an Untitled Rhino file. Your directory will be WRONG until you save it!", vbOkOnly
End Function
Hi Joseph - if you open your Step file with some code like this
Call Main()
Sub Main()
Dim OpenFile: OpenFile = Rhino.OpenFileName()
If isNull(OpenFile) Then
Exit Sub
End If
Rhino.Command("Open " & chr(34) & OpenFile & chr(34) & " Enter")
If Rhino.LastCommandResult() = 0 Then
Rhino.SetDocumentUserText "FileIOpened", OpenFile
Else
Exit Sub
End If
Rhino.Print("The file I opened is " & Rhino.GetDocumentUserText("FileIOpened"))
End Sub
In your later script you can retrieve the file name with Rhino.GetDocumentUserText(“FileIOpened”)
Hi Joseph - I was thinking that when you open your file, run a script like what I have above on a special file opening button or alias instead of the normal Open or Import commands. Is that what you mean?
(Call Main()
Sub Main()
Exit Sub
End If
Else
Exit Sub
End If
Hi Joseph - chr(34) is the " character so that the path is surrounded in double-quotes.
If the Rhino command line hits a space in a string like a file path and there are no double-quotes, then it will assume that space is ‘Enter’ and stop there. The Enter at the end is like hitting Enter after hand typing in the path.
Hi Joseph - you can check with a function like this:
Call Main()
Function IsSaved ()
Dim x: x = Rhino.DocumentName()
If isNull(x) Then
IsSaved = False
Exit Function
Else
IsSaved = True
End If
End Function
Sub Main()
Rhino.Print IsSaved()
End Sub
