Hello, i try to run this vb code but didn’t work in Rhino
And what is the equivalent of this with Python
Dim csx
csx = Rhino.CurveSurfaceIntersection(crv, sphere)
Rhino.DeleteObject sphere
If Not IsArray(csx) Then Exit Function
Dim i
For i = 0 To UBound(csx)
If csx(i,0) = 1 Then
If (csx(i,5) > t) Then
EquiDistantParameter = csx(i,5)
Exit Function
End If
End If
Next
dale
(Dale Fugier)
June 11, 2021, 5:31pm
2
Hi @anon39580149 ,
The code shown in the link is RhinoScript (e.g. VBScript), not VB. And the code does work in Rhino 7.
Here is the functional equivalent in Python:
import Rhino
def test_divide_curve_equiqdistant():
crv_id = rs.GetObject('Select curve to divide', 4, True)
if not crv_id: return
crv_length = rs.CurveLength(crv_id)
msg = 'Curve length is {0}. Division length'.format(crv_length)
length = rs.GetReal(msg, 1.0)
if not length: return
if crv_length < length:
print('Specified division length exceeds curve length.')
return
crv = rs.coercecurve(crv_id)
points = crv.DivideEquidistant(length)
if points:
rs.AddPoints(points)
if __name__ == "__main__":
– Dale
Thank you @dale
What i need is to use the idea of spheres in the VBScript to replace them with circles and don’t call DivideEquidistant directly.
Because it’s already available in Grasshopper ,and it is very slow with spheres.
I want test the original idea with circles.
dale
(Dale Fugier)
June 11, 2021, 8:43pm
6
Grasshopper does not use Curve.DivideEquidistant.
– Dale
dale
(Dale Fugier)
June 11, 2021, 9:02pm
8
Like I said, the Divide Distance component does not call Curve.DivideEquidistant.
What is the differenece between divide distance component and Curve.DivideEquidistant in GhPython?
I read in the old forum that divide component use spheres to find points like in the vbscript.
I find a solution, Thank you.
def EquiDistantParameter(crv, t, length):
EquiDistantParameter = None
pt = rs.EvaluateCurve(crv,t)
#sphere = rs.AddSphere(pt,length)
#csx = rs.CurveSurfaceIntersection(crv,sphere)
circle = rs.AddCircle(pt,length)
csx = rs.CurveCurveIntersection(crv,circle)
rs.DeleteObject(circle)
for i in csx:
if i[0] == 1:
if i[5]>t:
EquiDistantParameter = i[5]
return EquiDistantParameter
crv_length = crv.GetLength()
length = d
dom = crv.Domain
t = dom[0]
pt = crv.PointAt(t)
bdone = False
points = [crv.PointAtStart]
while bdone == False:
t = EquiDistantParameter(crv, t, length)
if not t:
bdone = True
else:
pt = crv.PointAt(t)
points.append(pt)
Comparing results with the code is better, i can’t know from the image.
dale
(Dale Fugier)
June 11, 2021, 11:13pm
13
Thanks, did you update the code of Curve.DivideEquidistant?
I don’t know if it is much faster now or not , but it is faster than the regular component
With code using circles it is faster but don’t work with self intersected or spiral curve
This is a test with the version 7.9.21162.15001
Divide distance work faster with 3d curve !
test.gh (6.2 KB)
