VaTable - Consistent Crash
Hey Guys,
I’m getting a crash when working with tables. Anytime the table is refreshed rhino crashes. I can send a file, any idea what’s up?
Edit - It appears to require an object in the table to have its description edited.
Edit 2 - OK and it will only crash if the VA Table panel is open.
Hi @Clayton_Muhleman which VisualARQ version are you running now? can you share a file that we can use to reproduce this crash?
Thanks!
Hi @fsalla sure thing!
Version - 3.3.0.19490
I’ll message you a db link.
Hi @Clayton_Muhleman thanks for the file, but I haven’t been able to reproduce the crash. When it happens, do you get a .dmp file in your desktop? please rename it (before closing the Rhino crash message), zip it, and send it over, so I can share it with the developers.
Thanks!
RhinoCrashDump.3dm (37.5 KB)
Hi, i have also crash with vatable,
Hi @Henry_Boutet_de_Monv please share the file of the video.
Unfortunately, the other file you have sent is not useful. When Rhino crashes, you will see a crashdump file (with the extension “.dmp”) generated in your desktop. Pleas rename that file BEFORE closing the Rhino crash message. Zip it and send it over, so we can view what’s caused the crash.
Thanks!
@Henry_Boutet_de_Monv I found your file in the other Topic, and could reproduce the crash! I’ll let you know when we fix it!
Hi @fsalla, sure thing. I’ll message you a DB link.
Thank you! We will revise this immediately.
@Clayton_Muhleman crashes related to table report panel should be gone in the VisualARQ 3.3 rc3 version we have just published: VisualARQ 3 - Version 3.3 RC3 released
Excellent, I’ll give it a test. Thanks!
That appears to have fixed it, bug squashed. Thanks again!
@Henry_Boutet_de_Monv we have fixed the crash when moving that window with the table panel open in VisualARQ 3.3.1 Update - VisualARQ
