Here are several attempts to subtract a reveal from walls. The results are incomplete.
SubtractSolidsIncomplete.3dm (600.8 KB)
It turns out that if the subtracting solid doesn’t align with the the interface between elements in the wall style, the operations will work completely. So I reduced the diameter of the subtracting discs a tiny amount as a work around. This seems like sort of a bug though.
Hi @djhg the solids need to interfere with the wall you subtract them from. If you change the absolute tolerance to 0.001 feet, the subtraction works well in your example.
