VaSolidSubtract for door panels
I see that if solids are subtracted from a VaDoor, they don’t follow with the door if the user adjusts its opening %, but remain where they were created. It would be best if they remained subtracted with the door wherever it pivotted.
You are right, the solid should move with the door. I’ll add this issue to our wishlist with your vote.
Hello @djhg,
We are still working on this issue, but in the meantime maybe you can use a solid of subtraction that follows the aperture of the door as a workaround.
I see, it’s a solid created by revolving a polyline around the doors hinge axis. Clever. Will be good when mouldings and hardware can be added to the panel though.
